Poly Decking Material
Looking for info on full poly decking to replace sled deck top. Thanks
http://mirageinc.com/nupoly-quadfloor-black-4-x-8
Chemical, moisture, and mold resistant cargo trailer flooring;
QuadFloor panels are a high density polyethylene (HDPE) overlay, factory laminated to exterior grade, 3/4" plywood.
NuPoly QuadFloor™, Black 4' x 8'
Chemical, moisture, and mold resistant cargo trailer flooring; QuadFloor panels are a high density polyethylene (HDPE) overlay, factory laminated to exterior grade, 3/4" plywood. QuadFloor panels are an economical solution for areas requiring scratch and moisture resistance. For nearly 10 years, it has been the premium floor panel for snowmobile, car, and toy haulers. Available in black, 4' x 8' sheets.
  • Skid resistant under both wet and dry conditions.
  • Protects subsurface from oil, solvents and grease.
  • Washable with soaps, cleaning agents and pressure washers.
  • Maintains a "like new" look longer than treated wood.
  • Resistant to abrasion from snow mobiles, ATVs, bikes, etc.
  • "QuadRipple" finish
What specific info were you in search of?
I have greatly enjoyed having the Poly-Bead floor on the last 3 trailers we have been using here at SnoWest.
Info on full poly boards similar to what Full Lotus uses. My deck currently has poly bead(NuPoly Quadfloor) is holding up fairly well. This is for a different deck.
What does a 4x8 sheet weigh compared to plywood of the same thickness?
Not such a factor with a trailer, but could be a potential downside for a deck.
