Polishing Tunnel
5.00 star(s)
I used this stuff I got it from a trucker it works good by hand even better with a buffer
about the time that you lose you ambition take it outside in the sun, then you will get your ambition back when you find all the flaws in your polish job. then when go and get another case of beer.:beer;:beer;:beer;
My wife loves it when I polish her tunnel. She said it works best with a hot dickens cider:)
She just got a new taurus from pinkley ford, so while I'm polishing her tunnel, I usually buff her pinkley taurus:)
Is that one of those fancy Taurus models, the CL model, you know cl-taurus?
OK, I got bored waiting for snow and decided to try this polishing tunnel thing. I started out with 400 grit and wet sanded every 200 grit to 2200. I washed tunnel off with water and let dry. I applied Mothers polish and buffed with mini ball in a small area. I got a gray sticky film that does not want to shine up or polish. I washed it off and tried again and got the same thing. I have rubbed hard with a terrycloth towel, and it keeps giving me a dull gray sometimes almost black film that will not rub or buff out until I wash it off.
What am I missing?
i dunno, i tried wet sanding mine last night, started with 800 and went to 1500 or somethin, tried the powerball and ended throwing it across the shop. NOT IMPRESSED. Now its taking forever to get it shined up. Maybe not consuming enough?lol
Not to say that the mothers ball is useless but I also bought one and was not impressed so I went to home depot and bought some buffing wheels and compound with an arbor and used my drill. I am still working on it but this is the fasted way to do it in my opinion. The buffing wheel are like $6/ea and the compound is $3.5 per tube, much cheaper and faster then the $20 mothers ball and $10 bottle of polish.
One of these days you guys will have to quit playing around with your drills and rags, and polishing liquids, and buy a wheel for the grinder, and some $2 jeweler's rouge, and do it right. LOL.
What I'm wondering is if the sanding residue is not getting washed off? Could it be mixing in the polish and causing the problem? Do I need to do some kind of acid wash?
81 I did not mention it but I did get tired of my drill and went and bought a 4.5" grinder, I have not used it yet but @ 10,000 RPM's I think its going to work much better then my drill did. I will post pics when I finish. I am hoping to get the rest of it done on Sunday but not holding my breath, even with buffing wheels it take a while to make a tunnel look like a mirror. I am also planning on doing the rails, and everything under the hood.
I started with mothers and didn't have any luck and was just about to give up but when I got the polishing cream in the pic thats when I finally got it to shine. A freind of mine is a truck driver and they know how to polish aluminum I used his variable speed buffer and started with the lowest speed 600 rpm and finished with 900 rpm and no wet sanding.
i use mine to shave with when i'm up on the mountain:) love the extra wide no-sno look;) long live the powerball/mothers polish, you just gotta give it some extra love...
les schwabs tires, has some polish called Heavy Metal in corse, medium and ultra fine. I use the corse the first time and med. the second time with a direct drive veriable speed buffer, then by hand with the ultra fine. I dont know if anybody has said that it is important to polish with the grain of the aluminum:beer;and good luck
