Can someone explain to me the geometry behind the idea that the you have to be seated, not standing, to weight the rear end and make the skid work properly?? Cant you weight the rear end from standing?? Doesnt look to me like the seat transitions motion and movement to the skid, could be wrong though???
As a flatlander I think I can help you out with this one
When seated maximum weight is on the rear of the sled. The body is dead weight. You hit a bump, mogul, drainage ditch, whatever and all that weight comes down on the rear suspension.
When you stand you will be leaning forward slightly and will naturally bend at the knees. You hit the same bump and insead of the full weight of the rider transfering to the rear skid, the knees absorb alot of the shock (unless you stand stiff legged, I cant imagine anybody would do that though). The weight could still be close to the same as seated but the inertia forces are way different.
For example jump off a chair and land with your legs stiff and jump off a chair with your knees bent. You will see the difference pretty quick.
This chassis may be something special or it could be a flop, only time will tell. I do think that it makes more sense to have it as a trail sled though.
Do you guys out west bottom out you rear suspensions much?
