Ok so here is the scoop.
2011 polaris pro boondocker kit, haven't installed updated airbox or EBC yet. running sled at 7500 ft.
Sled has a terrible and i mean terrible bog to it. So bad it will die at times.
Happens between 3100-5200ish RPMS, once sled starts to build boost it starts to go away, after 2ishlbs of boost sled runs amazing up to 8lbs (what i have it set at).
Running 50/50 av to 91 and tried 3/4 91 1/4 112. no difference there.
Compression is good
Reeds are good
Tried 10 different sets of plugs including iriduims.. They all come out looking fine, light coco color.
boost actuator is operating properly
no boost leaks that i can find
Tried all 5 of VOHKS preset maps, all the same issue
Tried some of boondockers maps, and some maps i've found online. all have the same issue.
Throttle body boots are fine
exhaust valves are fine
primary and secondary clutch springs are fine
sled doesn't throw any codes
sled idles around 14.7.. when the bog is happening it jumps from 12.4- 17.0 and any where in between. Soon as boost comes up afr numbers level out and pulls nice all the way to 12.4 at WOT.
Can't get it to happen as bad on the trail, get into deep pow and tree riding where you need that lower rpm range and thats when its super noticeable.
So what am missing???
Compression is good
Reeds are good
