Would like 2 if you are still making these. Will send you a PM.
Polaris Pro and Axys TSS Bypass $16
I have TSS Bypass Plugs ready to go:
- Corsa Connector (same as stock)
- Fully Sealed
Cost is $16 via paypal or venmo. PM me if you are interested.
If you aren't familiar with these, they are handy to have for several reasons:
- For testing (ruling out a TSS sensor issue)
- To override the sensor in the throttle block. Example is in case of an emergency in the field. If your throttle block is damaged, this will allow you to override the sensor and get back to the truck.
- Override for running an aftermarket throttle block that does not support the factory TSS sensor. If the TSS bypass is used, a tether needs to be installed for your safety. I highly recommend installing a tether regardless.
Thanks for looking and have a safe season.
--Perk
Sent you a PM with the ordering info. Thanks.Another one needed , pm sent
Looking to get a couple of these can you send me a link of where to get some or and please give a call Sean 760 937 3440Polaris Pro and Axys TSS Bypass $16
- Fully Sealed
--Perk
Thanks Sean - PM with ordering info sent.Looking to get a couple of these can you send me a link of where to get some or and please give a call Sean 760 937 3440
hi this is sean can i get the billing info again i can not find it thanksThanks Sean - PM with ordering info sent.
