TSS purchase
How do I go about purchasing two of theses?
consider a top end over haul . i just did one on my sons axys ,pistons were super loose. power increase was instant and very noticeableI have been battling with 8000 RPM for two years now. After reading this thread on top of the motor mounts I am thinking about swapping the ECU with another sled. If the motor is pulling timing there has to be a reason. A reflash of the ECU may not affect that function. I’ll have to wait for snow to tell you the details. Hoping that will help. I don’t know of any tuners that could control that function.
Time will tell.
Hi Bass - I sent you a message on how to order.No picture, but it is under steering post in velcro bag. Follow TSS wiring from throttle block to pouch.
Hi There, I'd like to get one of these. I'm in BC, Canada. ThanksI am making TSS bypass plugs for the Pro and Axys. Cost is significantly less than I have seen anywhere else (almost 1/2). I use the Corsa connector and it is sealed. PM me for details, or reply to this post and I will get you the info.
--Perk
Hey Perk - Sent you a DM as wellHi Jake - thanks for your business, I sent you a private message with the ordering info.
Can I get a resistor from youI am making TSS bypass plugs for the Pro and Axys. Cost is significantly less than I have seen anywhere else (almost 1/2). I use the Corsa connector and it is sealed. PM me for details, or reply to this post and I will get you the info.
--Perk
