Making room in storage shed and need to get rid of a bunch of 600/650 parts I purchased for an engine swap that never happened. Some of this was purchased off of e-bay, rest was purchased from fellow who had local Polaris dealership here about 12-15 years ago. Here we go....
-- EC60PL-02 600 block, crank w/ rods, cylinders and heads. S/N 84-02295 on lower case. Good shape, ready to use, stock bore on cylinders (could use a light honing). Rods have a little slop, center might be at 1/8" either direction limit. Purchased off e-bay two years ago as a combined auction from someone at Decker Racing in Wisconsin. Will only sell complete.
$350.00
--Set of three 600 heads good shape no pits $30.00/set
--Two 650 heads good condition w/ very small handling scratches $10 each
--Two cylinder head stiffener plates. Appear to be .090" thick. $5.00 each
--one set 3 EC65PL cylinders good to very good. With boots, appear to have been bored 1.5mm over to 678cc. Two measure 69.25mm, one measures 69.5mm--triple checked these measurements, same results. Light hone and they're good to go. $50.00/set
--One set EC65PL02 crankcases marked EC65PL03 s/n 90-02244 on upper case. Fair to good condition, some minor grooves in bearing area $10
--one set EC65PL01 cases marked 87-00254 Good condition no scratches in bearing areas other than some light cross-hatching (?). Marked .005" in marker on case. See note below. $30.00
--one set EC65PL02 cases marked EC65PL03 s/n 91-02658 Good condition one small nick in bearing area not deep at all. Possible evidence of cases having been line bored? Marked .010" in marker on case half. See note below. $40.00
--one set EC65PL02 cases no markings. Good bearings, 7 cylinder studs installed. $10.00
--one crank w/ rods, no mag end bearing. Pins are welded, not sure if rods are in spec, good core crank. $45.00
--one crank with all bearings and rods, un-welded pins ? rod spec. Another good core crank. $50.00
-- two 2/3 cranks PTO & center journals on both. One welded and other not. $20.00 each
--two individual journals, one mag, one PTO without bearings unwelded $10. each
--Three flywheels marked FP6382. One stock. Other two appear to have been drilled for balance. $10.00 each
Other assorted parts include:
--Jackshaft, stator, coolant rails, brake cooler from '85 Indy 600.
--5 stators conditions unknown.
--3 sets ignition coils
--5 front coolant rails, 4 rear coolant rails, 4 recoil assemblies in various stages of disrepair.
Note on crankcases marked .005" and 010"--Got these from a fellow who used to own the Polaris shop in town. Him and ontother fellow were partners in a machine shop, so these sets may hav been milled for higher compression.
All prices do not include freight. PM me with questions and I will do my best to answer them. Freight quotes will take one to two days to figure as parts are not boxed for shipping yet. I accept Paypal, but USPS money orders work best for me. Thanks for looking through this big list, hope I've got something you need. If you need pics let me know. Thanks!
Mike
$350.00
Mike
