That is what I am going to try next and here is why.
Today I checked the TPS and it is in spec so we went to ride. Today I ran it with a different ECU from my buddies sled with exact same setup (other than stickers) and still no different.
Had the go pro pointed at the gauge and seeing RPMs bounce off 8650 so I was/am hitting rev limiter. Switched to the 3lb spring and it was a little better, but still hitting the rev limiter.
Seems strange that at 8500 feet running 3lb spring turning 10-76 weights I am over revving. While my friend with identical setup runs a 5lb spring and his is perfect pulling 8350.
Can there really be that much difference between the two sleds that I need to run even more weight while running the 3lb spring?
