I'm working on my primary right now, and I originally was going to remove the weights from my stock rollers which I believe would be a pin weight off 10.5, but I am now going to be running a billet head so I'm told I should run a bit higher pin weight but not what amount..I currently have a set of adjustable pin weights 13.8 to 19.6 that I was going to exchange for the 10.5 to 16 gram?
With that said while removing the stock weights to drop it down to 10.5 one of the weights is jammed in one of the stock pins and striped. In light of the billet head should I put in the Team weights @ 13.8 and adjust from there, or order the adjustable 10.5 to 16 weights and start it at 10.5 and adjust it up. I'm guessing the increments would be 10.5 empty, 11.?, 12-13, and 16.0.
Other info running at 8000'+
Trygstad billet head
19t gear
415 Ramps (thinking of switching to the Team 415 ramps, not sure though I may return them I didn't realize I had 415 ramps stock...is it worth it to change them, I believe they are lighter )
Yellow / Almond Spring
Team Tied Secondary
800r 07 151
Thanks
-Brahm
19t gear
Team Tied Secondary
800r 07 151
Thanks
-Brahm
