You may want to pull your pump cover and check the impeller. Maybe some material went through it after the top end rebuild.
Daltech may have hit the nail on the head. When you pull the head, you should be able to see tracks on the head or cylinder where it has been leaking.
check the guage and the sending unit, very well could be a gasket leak though
Low rpms no problems, under boost over 6000 high heat problems , check your fuel octane ? If running 91/92 go 50/50 av ? Det problem ? Another idea, an old load of fuel with the lites out of if could cause heat from low oct ?
Is there any rolling resistances such as track, bearings ? Check clutches ? Rollers Something is creating load ? Air restriction to turbo ? Routing problem on coolant lines? Seems like some of these problems might show up at different RPM levels 5000/6000/7000 ect if you can hold long enough to check ! Also try using a heat gun with laser lite ! Good luck ,
Did you remove the flywheel for rebuild? I have witnessed sheared and missing keys. May need to check timing.
Injector change and/or reflash?
We need a scratch head icon.
The coolant bottle neck top is notorious of being distorted by impropper pressure cap installation. With a known good/new cap in place, use a pressure gauge with a small hand pump to pressurize the bottle through the bottle vent port. You should be able to pressurize the bottle up to the release pressure. If you can't raise pressure the bottle is bad and needs to be replaced.
I've been watching this thread with curiosity and did comment once. Obviously it is hard to diagnose a problem without being there but I did have a peak track and at times it ran hot. Sometimes it didn't as much but generally hotter than stock track. When I put stock back on it for sure ran cooler. I could run in some conditions with peak on groomed trail to our destination with scratchers down with say a few inches of fresh and still run hot. Maybe this isn't your problem and I am not saying it is. Hope you find something else that is easier since you like the peak track. Good luck and be safe
Looks like it runs good man! Wished mine ran like that....Grrr
