PCV or PCIII on 700 cfi
07dragon
most topics about these are for 800's. but i am assuming they can be used on 7's too? anyone done this to your 7? does it gain enough performance to justify to purchase? and how reliable does your 700 motor stay with one installed?
thanks
i bought a 08 700 from a guy that had the pcIII usb on it, right away i wasnt sure a bout it but finally found a company (dyno tech reserch) who does alot of testing with the power comanders. he has dyno sheets with differents setups. i have a hps can otherwise stock. i got a fuel map from him for my application and its a noticable difference and seems to run a more consistant air/fuel ratio so its alot safer from what i have seen.
thanks
I have a 2007 D7, PC-3, 4500+ miles on it.
I list the PC-3 (or PC-5) as the best mod for the sled, currently running DYNOTECH JIM'S MAP
WWW.DYNOTECHRESEARCH.COM
Check out my TECH TIPS FOR 600/700/800 CFI's pinned at the top of this section under "INCREASING YOUR IQ"
i was just looking at your thread kraven, and seen you said best bang for buck was the pcv or III but never connected that you have a D7 also. did the pc 3 add power? im sure it did. just never hear of anyone putting them on 700 only 800s
PC-3, PC-5 same performance, just the PC-5 you can add Auto-tune
When stock, my D7 was PIG RICH on top end and LEAN in the mid-range (as in over the handlebars lean)
I'm approx 10% RICHER in the mid
5-10% LEANER on top
DEFINITELY a noticeable performance improvement, and much more trail-friendly to drive.
I just noticed you have a SLP single pipe, DYNOTECH Jim has a map developed for a SLP piped 700 as well, as he dynoed a 2008 D7 with a SLP single on January 1, 2009
