PCV Maps
Does anybody have a pcv map for a stock 2009 800 rmk ? I just bought one today but have no maps. Slp only provides maps for their pipes etc. I am looking for something not to extreme but need to gain some rpm back from polaris so called updates/recalls.
If you're running the original 2010 Polaris map in your sled, then you can run the SLP map in your sled with the stock pipe with good and safe runnability.
anyone running the slp map on the original 2010 flash?
im looking to try it out, as i got the original 2010 flash on my 2010 800.
What about the map DTR is running on stock 2010's? Anyone running that? Looks like a healthy power gain to be had for relatively cheap?
pcv mapping
Thanks guys, I installed Jims map from the April reflash, I had to lean out WOT and added some to Midrange.Runs better but at 9000-10,000 ft I'm only pulling 7800 RPM anybody else had that problem?
