I haven't had any issues and don't use stabil on anything else.This might be a silly question but it relates to 100LL so I'll ask:
Is there any issues with storing a sled for the summer with 100LL in it?
Should I use any Stabil or anything?
I'm still runnin 100% av gas at 10-12 psi, no issues at all![]()
X2 for me as well with my Silber Kit!
On 2 stroke mercury race engines 5 motors, 4 stroke...lol...maybe 1000+ at least... My good friends shop builds nothing but 2 strokes,n/a and turbo..hes done maybe 300 motors. You find after years of testing that all motors tend to perform very similar with respect to fuel, air temp, ect ect. We even did a couple of turbo mazda rotary motors (strange beasts) I did a huge amount of dyno time on blown gas deals, we had the fuel octane dialed in pretty good after 20 years. You can actually figure out the aproximate required octane needed if you know the true running compression on a engine, Quick and dirty formula for this is:
Final Compression Ratio (FCR) = [ (Boost÷14.7) + 1 ] x CR for sea level Note: the (+1) is dropped when boost and atm pressure are >1
Where cr is true static compression,14.7 is atmosphereic pressure at sea level. (final compression numbers have NO corelation to static compression numbers ie 12-1 FCR noes not = 12 -1 static !
Now Air pressure above sea level can be calculated as (just use a chart..lol)
p = 101325 (1 - 2.25577 10-5 h)5.25588
where
p = air pressure (Pa)
h = altitude above sea level (m)
final compression can be determined and octane needed can be picked. Now its important to remember that the number you get for final compression does NOT in any way compare to the "normal" number you see for static compression, ie 12-1 does not = fcr 12-1. This is only used as a ballpark # to see where you are at. Many things play into effect here, ignition,intercooler,port timing.exhaust flow, ect ect ect but as a starting point a FCR of 12-1 is good for 91octane, somewhere around 16 to1 for 100ll or C12, above that C16 or C25 till about 25-1+ where things get touchy...lol..
So for our motor at sea level running 12 pounds of boost and 12-1 true static(polaris dragon 800) whats are running compression? well:
[ {12.0 / 14.7} +1] x 12= 21.7 to 1 running compression under load
now same engine at 10000 feet
[{12.0/ 10.245}] x 12 = 14.00 running compression (10.245 is atm at 10,000 ft)
So we see that 12 pounds SHOULD be safe at 10,000 feet on 100ll blend and at sea level better have some C16 in it.
Is it safe? well we now look at what guys are running, ummm , many running 12 pounds boost on 100ll with no issues so we conclude by our formula and real world data that is should be OK.
Remember THIS IS A STARTING POINT ONLY. THERE IS NOTHING AS ACCURATE AS YOUR OWN PLUG READING,EGT'S,PISTON WASH,BURN PATTERN,AFR ECT ECT TO DETERMINE OCTANE REQUIREMENTS. Different chamber and about 1000 more things...Every motor has its own requirements and you learn what to do by years of experience and testing. NEVER put a motor near the "edge" unless you are totally willing to accept the FACT that it can melt to the wrist pins in a split second no matter what/who is tuning it thats just a fact when pushing the limits. Thats why I don't get to upset if I blow the rods out the bottom of the block...$hit happens or as they say "thats racin bub" lol.
Other guys figure all this different ways, first thing you learn in engine building is that nothing is the same..lol...and only trust your own data..are others correct?? Maybe, are there methods better? Maybe, the only thing I ever cared about is who's kissin the trophy girl at the end......................................
The "snappyness" of a motor you can tell pretty easy on the dyno fron the rate of acceleration over a given load, ie, the computer on the dyno is programmed to apply a fixed load over a time interval, then you can see how long the test engine takes to accelerate this load to the spectified rpm.
Or the dyno can be set up to give you a reading of how fast it has to open the water break in order to hold the motor, then apply this data to a acceleration curve you can look at.
Before we had all this computer stuff to control the break (way back when) you operated the brake with a wheel, primative as it sounds it was pretty easy to feel how fast the motor gained rpm by how fast I would have to apply the load...lol...and let me tell ya you crank that baby pretty dang quick on a blown alcohol deal..hahaha.
