P85 on Boost
Trowing a P85 on my RMK Boost. Looking for a start point for tuning, would like to gain bottom end over factory as I like tree riding. Im not new to clutch tuning just curious what others have tried. What works what doesnt? what about secondary as well?
carbontj
228
428
indianapolis
Just need to add a defection bolt...Heard nothing but good things from the people we did P85 for and the Boost and 9R...all super happy!
M
Nov 5, 2012
67
14
8
32
Sicamous B.C
Are you guys running factory boost springs in the p85?
I have an ibexx stage 3 ( axys turbo kit ) helix in secondary and spring and weights from my 2019 in my p85, was curious if I could just slap the full clutch in and adjust weight or what is everyone doing!
I see ibexx has different style weights for the p22 and boost but both should work?
Application 2024 boost 155.
madmax
3,151
Salt lake city
Unless your really good at clutch tuning I would just buy the TRS P-85 boost clutching instead of trying to piece together a bunch of left over old stuff. Make sure you also set your alignment, the matryx alignments have been way off from the factory.
R
Reddragon800
267
409
If your running a P85 on a stock boost, run 10-74's or EPI 74g belly busters, with a 140/330, secondary should be a 56-42.36 with a 175/240 secondary spring. Some adjustments will need to be made for track lenght, elevation and rider weight.
if your running a 10hp tune, go to 76g weights.
T
Dec 19, 2016
18
1
3
Alaska
I'm in Alaska running 3-6k feet you think i should still start on 74g or start with 76G ?
Teth-Air
4,585
2,814
Calgary AB/Nelson BC
www.specified.ca
A buddy put a P85 on his 9R and the clutch snapped off and it was a chore to get the shaft off the crank without damaging it. Warranty is void for such a repair if you plan taking it to the dealer if something like this happens.
T
Dec 19, 2016
18
1
3
Alaska
Ya Im trying to prevent P22 clutch snaping the bolt off I have seen it on 3 diff sleds this year. I have a bad ass dealer so not worried about the warranty. P85 is a pritty tried and true clutch. I am just looking for a good baseline to start from when installing. I already have the clutch gonna stick with stock weights.
CROW
1,479
211
Michigan
What RPM are you seeing with this setup? Did you switch to small rollers in the secondary?
carbontj
228
428
indianapolis
Just a quick FYI....the stock P85 new is $665.00 for a new P22 cost is $999.00. these P22 wear out within 400-800 miles...P85 last a lot longer!!! I work with the P22 most days and noticed that the aluminum they used on the clutches is so much Softer than P85. has zero heat treating compares to p85
