P-Drive Timing Question
titus_4
BCA Klim 509 Sled Head
Took apart my clutch to install a clutch kit and didn’t mark my clutch until after I smacked it on the floor to split the pieces. I don’t think I moved the clutch around when hitting it but going to reassemble it looks like my sharpie mark is 180* different than what looks like a timing mark. See pics.
This was how I marked it. Any other mark you might see is just a reflection (besides the 4 milled holes to the right).
This is what looks to me like a timing mark and I assume should go in line with the circle mark at the top.
Any help?
Also, writing in our out on sprockets? I always thought writing goes out, but when I opened chain case, top and bottom sprockets are both writing in. Maybe it doesn’t matter.
There should be a straight line on the rim of the sliding sheave that matches to the line on the fixed sheave in your second pic.
As far as the sprockets, kinda doesn’t matter unless.
That circle is the only mark on that sheave.
Arrow on the spider aligned with the circle on the sliding sheave.
Line on the sliding sheave aligned with the line on the fixed sheave.
Thanks. I don’t think there is another line on the sliding sheave, just that circle, but I’ll double check it tonight. Still mad I didn’t just mark it before taking it off the machine like I normally do.
Found a super faint line in the sliding sheave with a little paint mark above it. That look right? Then line up with the notch below it. Can’t believe I missed that.
