P-85 primary
F
fordpickupman
I am looking for the tolerances for the buttons and weights and such for this clutch? I did a search and only came up with dragon centerline rightups.
When checking button clearance (between buttons and tower), make sure to check the clearance at the bottom of the travel as well as the top. With an older (worn) clutch, the button clearance might be tighter at the bottom (sheaves fully apart) than it is at the top (fully shifted out). If you add shims to get tighter clearance at the top, it might bind at the bottom.
Thank you!
These forums are a great asset, I have gained some new friends and now my clutch is rebuilt and I ended up with some tools to make it easier.
I will be a paying member as soon as the next pay period comes around. The price is worth it.
thank you dukrider.
