C
chevnrev
New member
So, one of the last kinks i have to work out of this turbo project, I have my turbo installed, and i tried starting it with the pure logic box hooked up, and it won't fire at all. If i put a little gas in the cylinders it will start up and die from lack of fuel. I have the injectors hooked up to the correct sides of the pure logic box, with yellow to yellow and green to green, yellow on mag side, green on pto side. I read some posts about sometimes having to switch around the wires inside the plug for the injectors for it to work, but I thought this was on M7's. Could that be the case on my sled? It WILL start without the pure logic box hooked up, with the injectors hooked up in stock form. If I have to switch the wires around, what type of tool do I use to get them out of the plug to swap them?
