Ok guys, so I have been out sledding a bunch and we have had awesome snow, I now have figured the settings out to make the sled run great, it doesn't burp or hickup nothing, it pulls good, which brings me to my problem.
It is only hitting 5lbs boost, it will flash to 6lbs but then sits at 5. I took apart the turbo diaphram just like aerocharger suggests and had a look:
It has the orange spring and had 3 shims, I added another shim to see if anything would change but nothing.
So this is where I am at, today on a climb I could have used the other 5lbs of boost, as that was the difference between diggin and making it, needless to say I was diggin, with the help of a couple guys who purchased our Full Lotus decks, that just happen to be there and watched me almost make it.
Anyways what could be the cause of not making full boost, ocassionally under full load when I am making a long pull it will flash up to 6lbs settle at 5lbs and then give a bit of a cough and start dying out, then I back off the throttle and burp it and it comes back to life.
Do you think I have a leak somewhere in the charge tube portion of the turbo? All I know is it is suppose to make 10lbs boost with orange spring and two shims and it is only making 5lbs boost with orange spring and 4 shims.
Lets hear it guys, other then that I finally have some confidence in the turbo system and have learned it's quirks to be able to ride it well.
Thanks
Jeff
