G
GREICO1
The 5.1 PRO track was uses a STIFFER durometer than those used on the Dragons (confirmed with Carl's) so your comment has no bearing on this discussion. In fact F-Bomb doesn't even use screws in the Pro's 5.1 track because it doesn't need them (and would trench terribly if you did use them).
Here's something to ponder - for every 1/4" you cut (which is about the length you'll cut just taking off the tips) you will gain 4 mph track speed (this isn't a guess, I've heard this from Camoplast as well as DJ of northern catalyst) and that is exactly what I found on my sled. Ran it all last year with normal track and this year with cut track. ZERO regrets, better top speed, better track speed, better braking and better downhill control. Might be a slight dip on deep pow initial float but the increase in track speed makes up for it, once moving, from what I've seen.
I was leery about cutting mine too but the last straw was when I saw how much the lugs were folding over with just the weight of the sled on the trailer. After cutting they have about the same bend as the Challenger track on my Summit which has proven to be an excellent all-around track so I was immediately confident that I had done the right thing. Best product to cut the track is the Craftsman Handi-cut; change blades half-way thru and spray with silicone spray; easy job!
http://www.craftsman.com/shc/s/p_10...ord=cutting&prdNo=10&blockNo=10&blockType=L10
My 2 cents,
G MAN
The 5.1 series single ply track is the same track used since 2009. The change in rotational mass is however, spot on. If you want a 2.4" track, leave it alone. If you want something shorter, by all means cut away. The shorter lug will be stiffer, and will work better in heavier snow, or later in the spring when the base has setup. The tips of the 5.1 are the soft part of the track and work very well in light, deep powder, but will fold back when the snow is setup. The 2 inches closer to the main belt of the track are much stiffer, and will perform more like a challenger or comp track. Decide where you ride and in what conditions, and do what you think will work best in your situation.
