opinions neede should i upgrade turbo or run it?
bought a '10 m8 traded in my 07 which had the bd rg kit, older style intercooler and what not. i've been told that this kit needs a lot of changes to run right, such as different airbox fuel system and what not. it is an ada kit i upgraded it last year. im basically trying to decide if i should install this kit, upgrade it or go a totally different route any opinions would be appreciated thanks.
have a look at push turbo kit......this kit is the next step in the 2 stroke turbo industry.external waste gate and injector in the charge tube make it, in my opinion,the best put together kit right now on the market.pump gas,blowoff valve,waste gate all built by turbosmart in australia ans very high quality product.Ken is a realy nice guy to deal with on top of it!
http://www.pushturbo.com/
If you ran it on a previous sled, unless it sucked, I'd question the "requirement" to upgrade it. On the other hand, I have this same kit, and am considering the upgrade of the oiler unit, only because I am highly advanced in flipping sleds on to the rubber side up. The new oiler IS an improvement in this case. So far have not flipped the turbo, but the odds are not in my favor. Not so certain about the other upgrades.
Just my 2.
have a look at push turbo kit......this kit is the next step in the 2 stroke turbo industry.external waste gate and injector in the charge tube make it, in my opinion,the best put together kit right now.
I have to agree. The Push turbo looks to be a considerable advancement. If I were buying today, hands down, it would be where I would go. (Not that the BDRG turbo sucks. It doesn't)
Not bashing by any means but why do you think injectors in the charge tube are better then after the throttle plates?
Mike
I have been Talking to Travis at OVS and it sounds like the M8 kits he is building are absolutely awesome... For one thing the PL box destroyes the boondocker box... (IMO) And I have used both... He is running a bit bigger turbo... Uses a bigger compressor wheel, produces cooler boost... And will run 14 pounds all day with no intercooler... The tial SS turbine housing is mint, and I think they have the slickest external wastegate setup out there...
He has crushed every question I had with ease and I really think has built enough kits and done enough homework to really know what is going on...
Check out the pic mmsports put up in this post and tell me that is not freakin awesome!!! http://www.snowestonline.com/forum/showthread.php?t=193294
