I said it before, should have payed a dealer to do it. I did the same thing so I had to tell myself the same thing, worst part is I did it twice. Just not worth it. Hope you get it figured out, best of luck.
A weak coil on the stator can cause a lean condition due to the fact that it is not supplying enough voltage to the fuel pump and fuel pressure will be too low. Injectors have a pulse duration calibration and fuel pressure is critical to delivering the proper amount for each burst.
I am going to go back to the warm up.
When you have lots of fuel it is cooling the top of the piston off so your EGT's look good, wash is good, no indications of a problem. But the skirts on the pistons will swell if not properly broke in and you will not have enough clearance. Thus they skuff.
It is either crap left in the motor when you put it together. (But it doesn't really look like this is the problem). Or the pistons grew faster than the cylinder.
Thunder
I just dropped it off at Big Boys Toys so we will see what they say. But I think you are right. I think it seized because I didnt break it in right.
