It may be just me, but I thought the footwells seemed tighter. But I did not throw a tape on them, just seemed to feel that way to me. Go figure, everyone else says they were more roomy.![]()
Here is a few of my observations; While the theoretical realized ratio may well be 2.25. To get there they they actually geared it higher at the QD. From the pics it is now a 43 Tooth lower sprocket (was 44 Tooth on the PRO). The center to center distance is only ~1/4" longer (scaled from the pics). Which makes sense if we assume they are continuing to use the same top sprocket and QD belt. That means they made up the 11mm (one tooth pitch) of distance gained by stretching the center to center distance. The PRO QD was a 21/44 for a ratio of 2.0952:1 the AXYS QD by all indications is a 21/43 for a ratio of 2.0476:1 it only comes close to the 2.25:1 when you add in the driver size change to 7 Tooth.
I'm not a fan of the status quo accepted use of the smallish 7 tooth driver. And I'll never run a seven tooth driver, even 8 tooth is too small for my liking. That said, I understand why most of you have chosen to endorse it's use. As that is what the market will tolerate cost wise. I find it SAD that the factory engineers have endorsed it's use and actually built a sled using this crutch necessitated by their poor engineering on the PRO-Ride chassis. When the next lug size track gets developed, will we go to 6 Tooth drivers, 5 Tooth? For this reason the engineering staff responsible for this portion are Idiots, IMO. Complete lack of forward thinking. No room for growth or expansion.
I may be alone on that sticking point, but I'm not budging from it. And no one to date has had a valid argument for going to the seven tooth. It is cheaper, period! NOT better by any stretch of the imagination.
In spite of that; I can see a easy sub 390# dry weight for far less than cost of a new Skidoo. First a Diamond S Ti silencer. Replace the fasteners with Titanium starting with the largest most stressed ones. Replace the smaller low stress fasteners with hard anodized Aluminum (like the tie rod boot bolts and others that are just holding plastics in place and such, no need for heavy steel or expensive Ti for those). I suspect that for about the cost of a new Skidoo we can have a 375# sled and for a bit more a 350# sled.
All without sacrificing any Reliability.
Man I really wish I could get Loudhandles honest opinion on 7 tooth drivers Ive never heard it before...
So is the new track 2.7 or 2.6??? Where are you guys getting 2.7 I keep seeing 2.6
Humm
The sled is taller.
More clearance to the snow.
But the approach angle is better.
Liking the new fuel tank.
Console removal without taking the stupid nut off the gas tank. ��
I don't think the approach angle changed at all. I asked them about that. The front end is taller, the plastic is pulled in tighter out of the way but the suspension mounting hole in the front is lowered and the drop brackets are taller. Different arms on the suspension.
will the new seats be interchangeable? Just bought a new skinz seat for my 14 pro
I was basing that on profile shots and manual measurements.
I'm guessing you were basing that off the profile pics in post #9, I too thought the AXYS looked like a shallower angle, but after looking again, I think that is due to you actually being able to see the flat on the AXYS and on the PRO you are essentially guessing what and where the flat is because it is mostly obscured by the tunnel and plastics. From the pics and how you judge the PRO I think it could go either way. Also in the photos they are not truly parallel to each other, nor flat to the plane of the picture in either direction.
Time will tell when we get them in our possession.
