I usually run Amsoil 20W-50 in my bikes during the summer months. I found going to 10W-40 helped with cold starts last winter.
A conoco rep told me the main purpose of newer diesel oils is to reduce the amount of ash going into the dpf, which clogs it. He recomended more frequent change intervals using newer oils in pre 06 motors without dpf's. Don't remember the chems it is lacking but moral of the story is its not as good as older api service oils. Should be fine in a dirt bike with needle bearings on every moving part,ie very durable, if your clutch likes it i cant see it mattering what oil you run.Seen an article in dirt rider about a suzuki going strong for 40 mins with no oil at all!
Kawgrn on the 570 do not run anything but a really good synthetic. The way the cyl head is positioned. It does not get as much oil to the top of the intake valve. As it does exhaust. I had some ware issues on the intake adjusting shims running the yamaha oil. I fix the shimes and ran klotz mx4 15-50. I had no more issues. I pulled it apart at the end of the season and checked it. There was no ware.
Thanks for the advise, was thinking amsoil syn 10-40, there are lots of oils but my rekluse clutch needs the right properties also,summer use was motul but hard starting when its cold, which is why Im on the hunt,thought the yamaha oil was a synthetic?
