Should you cap off the old brass oil nipples that go into the case? I would think you would need to or you could lose vacuum for the Raves and DPM.
Rt
Those are good photos, Its more than I installed, I simply plate the oil pump location, Plug the brass injector holes and put one clear tube up about 10 inches and plug, Its just an inspection tube so every now and then while servicing unplug the tube and assure the oil lever dosnt drop.Or run tube to small oil reservoir. You will need to hang sled from rear bumper to fill oil cavity before installing the plate.The advantage to the photos shown is you dont need to burp the air from the oil pump cavity[Self filling system] All ideas will work.Remember the oil will not circulate or be used unless main seals leak
