No The oil injector is simply 2 small holes[Brass injectors} on the cases. Oil sprays/drips down the inside of cases and the Air/fuel turbulance is what picks it up to lube bearings. Premix does a far better job since the mixture is allways consistant, Plugs are cleaner and motor will run crisper and you will loose weight.Correct me if I'm wrong here, but you may need to drill the case for the PTO and MAG bearings to allow oil to the bearing with premix, I do know on a 2004 800HO, when deleting the oil injection that is what is highly recommended.
The Fuel /air mixture gets forced into the crank cavity by the piston action,It does a much better job lubeing the bottom end, And nobody would chance only running 1 quart, I have seen a few only fill half way but most fill the oil.Granted that will help the weight concerns only a bit.Funny you say that, when I had my crank rebuilt, the guy who did it said that they used to drill and tap the case to drip premix oil down into the bearings INSTEAD OF running isoflex grease. I never did it, but you reminded me of it!
When you take off to ride your sled is at least 8 lbs lighter. Tell us how much a gallon of oil weighs? -oil pump.and plastic. I can tell you, I weighed it and many others who have done this mod can tell you as well, You however have Not done this and should just keep quiet,Since you have not completed this mod , This consistant perfect feul /oil ratio helps an engines life as well.You do not need a reservoir just a clear inspection tube.Your fuel tank is full with premix instead of just gas.and that it! How much $ does it cost in after-market goodies does it take to lose 8 Lbs?.
The Fuel /air mixture gets forced into the crank cavity by the piston action,It does a much better job lubeing the bottom end. QUOTE]
Yes, but Rotax motors are packed with grease and sealed. The PTO/Mag side bearings never see oil conventionally! They were drilling and tapping a hole in between the two bearings, and allowing oil to drip into the cavity, then the oil would just pass through the inner oil and be burned up through the motor. Every doo motor I have ever pulled apart that ran grease needed more by the time I broke them down, maybe the constant feed of oil would increase the life of the cranks? maybe not? Has anyone ACTUALLY tried this? experiment?![]()
First of all I have done this MOD, I have sleds with and without injection systems,Perhaps you should read more clearly. Second.LRD indicates even more weight loss,9.5 lbs and is correct on better engine performance And third i,m 48 year old and if you have been doing this mod before I was born,Well I wont address that, Have 25 years of Mountain riding as well. For flatlander riding the weight may not be as noticeable or as important.I just cant see why one would choose to have the additional weight and the only advantage to injection is the absense of premixing. I,m always looking for that edge and 8+ pounds is a real good start.You say that I have not done this mod. and then go on to attack my point of view. Yes, I have done this mod. I have been modding sleds sence before you were born.
Like I said. Start the day with 1/2 gallon less fuel and 1/2 less oil in your tank. You will get the same results as an oil delete. That is 6 lbs right there.
I didn't say that there were not advantages to a delete kit. I simply stated that by deleting the oil injection system, you are just starting the day with less fuel in the tank and less oil to start the day.
1/2gallon of oil is 4 lbs. 1/2 gallon of fuel is 4 lbs. 4+4=8lbs. Same as the delete.
Cost of this mod. $0
