Who has rode their MPI charger yet. Wondering how it is working. Heading out this weekend on mine for the first ride. We have no snow here to test it.
We put about 50 miles on a Stage II Nytro on Sunday. The power is saweet. Do yourself a favor and take all the necessary tools to pull the oil can off and check your bottom taper lock after 10 miles, then 20, then 30 just to make sure it stays where it should. Take a straight edge so you can realign if necessary. The beauty of a s/c is if something does break, you can take what is broken off and plug the stock mapping back in, and ride the rest of the day. Good luck, I'm sure you will love it.
jw
p.s. The mapping needed slight adjustments for the elevation, etc......but we were able to make it spot on through the whole range. Also, did you reclutch? If not, you will need to!
