NYTRO steering relocation
You still working on the running boards???
Yes.
KCBOOST i'll post some pictures tomorrow . Kit is 99.00
The post stays in the stock location on the bottom mount. The top mount gets raised 2.25" and it changes the post angle by 5 degree's. It helps with the handle bars swinging down towards your knees.Gives it a more traditional steering feel.
MOB I have to re machine the greasable billet bushing blocks to fit the relocation.
I will be doing them when I get some free time probally in a month.
Wildchild, does the steering kit mentioned use the stock raiser or a Powermadd type?
You can run any riser . The kit just relocates the stock post or a 4130 post if you want to run a "t" top.
Heres some pictures
First picture is the stock location
Second picture is location of the post relocated
Third picture is dimension of stock post
Fourth picture is dimension of relocated post
Fifth picture is the top bracket mount , kit comes with new bottom mount machined to fit the new angle of the post.
nytro relocation 031.jpg nytro relocation 026.jpg nytro relocation 033.jpg nytro relocation 029.jpg nytro relocation 025.jpg
Code:
does it help with handling or just change where the bars are located
It helps with the bars going down towards your knees when you turn.
The kit gives the nytro a more traditonal style steering.
It moves the top of the post up only, bottom stays in stock location . top of the post is rasied 2.25" and changes the post angle by 5 degrees.
