Nytro ski pressure
From experience with this skid you have to go way more then 1 bolt hole. I think the cr adjustable hole brackets will give it one inch of movement.
how about a stock 09 skid is there anything that can be done to it for less ski pressure other than suck up the front straps all the way which makes it a tank to steer.
Crank the compression up on your front skid shock up real tight, also loosen limiter strap up.. Firm up your front shocks as well
thanks jrusher done all of that but loosening the limiters make it a trench monster.i did notice that the rear suspension sits farther out of the tunnel with the cr racing brackets that i put on compared to the stock ones might have to modify them to put suspension back into the tunnel some more and take pressure off the front.
Ya if back end of sled is high try an raise skid up at back drop brackets or even front an back if possible an level out sled more. I ran cr tunnel on my nytro an m-10 type skid I can't remember where I had my skid mounted but it sat pretty level.. It still had quite abit of ski pressure but it's hard to get away from with that type of skid.. What skis you running ?
I just put a set of polaris grippers on my Tnytro with a racers edge skid. I have run simmons gen2, simmons gen3, slydog powder hounds. The grippers are nice I would highly recommend them if you are having darting or too much steering effort for your liking.
i have the stock skis but i am looking for a pair of Polaris gripper skis to try.
i put a star suspension kit in my nytro which made it a lot better to ride but still have to suck up the limiter straps in deep snow to stop it from trenching.
