H
Hrt Offroad
Mine was acting up again this weekend without even running it very hard. I'm going to mess with a few things this week...so I'll keep you all posted as to the results.
I find that the fuel lines collapse and kink fairly easily when hot. My oil return line did this as well, but since using a stainless braided return line and angled fittings...the problem there, seems to be rectified. I'm going to plumb my fuel lines with stainless braided and AN fittings. My sled ran flawless over X-mas holidays when it was warmer temps and neck deep pow, but everything was still brand new. So, we'll see if this fix helps or not. Maybe the lines are becoming softer after every ride - making them more susceptible to collapsing!?!? In Automotive applications - fuel lines generally have more air space around them and if they are in in high heat performance applications - they are always stainless braided or hard lines.
Just trying to figure out whether I should use -8 or -6 for the fuel lines...any suggestions???
P.S. Since this started happening I can notice a loss in performance and throttle response (hot or cold)...anyone else?
