hmm a little more thought on this. lol
but this is a good one i think!
Ok, so you do the "go up and make a U shape at a point higher than the tank", and at the top of the U, you put a T fitting. the straight through end will go down and dump near your foot well. The other fitting will dump back INTO the oil tank.
This way a LOT of the oil should dump back into the tank, and the breather will still breath.
Hows this sound?
Aside from having to come up with a way to dump the hose back into the tank, it sounds like a pretty slick/simple/easy setup? That should stop maybe 85% of the oil loss?
Or is this where you simply would install the 'collector tank', so this aux tank fills w/ oil and you dump it back in at the end of the day, or if you need it (due to oil light coming on).
OHHH now i like that idea... how bout using one of those small 8 oz pop bottles? I bet the opening is close enough to get something rigged up to fit over a hose? or even screw on/off?
Ok, so maybe i need more time to figure out what kinda 'catch can' system to use...
Granted, having it dump straight into the tank is the best option..I just don't think it can be done as easily...
Ok. Heres the bottle I want.
Install a 5/8" OD screw-on fitting into the bottles cap.
Attach a couple inches of 5/8" ID hose from T-fitting to bottle fitting.
Screw bottle onto the cap.
Now we have a screw on/off bottle that we can easily empty back into the oil tank. And can easily see if, or how much oil would have been lost!
I'll be building this tonight..
So, how do I mount this bottle? I could set it up to almost be an catch and release setup if I'm visuallizng this correctly.
If the bottle is attached 'upside down' and before the top most point of the arch (but closer to the can than to the 'dump side'), it should in theory, fill with oil when its on its side or upside down? And when its put back on its feet, the bottle will empty back into the hose, and if placed right, should empty back into the tank and not out the 'breather end' (or into your belly pan).
Hmm, ok time to bring ideas to reality..and see what I can do. lol
Hopefully I'm headin the right way. Let me know if you see flaw in this logic!
