This fall I did a few changes on my chaincase and noticed that spring retaining bolt had broken off. I put everything back together and all works fine. Earlier this fall I had it in for some warranty and had them replace that bolt.
I noticed today that it was really hard to put the sled into reverse, and no matter how much I jiggled the handle or moved/rock sled it did not want to go into reverse. After I got it into the garage and onto the lift it would go back into reverse but seemed to be very finicky on handle placement on whether it would actually engage the reverse.
When I would pull back on the lever it would not drop down, felt like it was binding or when you put the chain case back on wrong with out the tongs engaged into the gear.
I am wondering if the drive chain is to tight?
What else would cause this.
Never in 2000k have I had it not go into reverse with minimal effort.
Later
Later
