Nytro clutching
It's not really technical, you pull the weight out and punch a rivet out and reasemble
Dont try and make RPM with your secondary but you may need to crank that up too
First thing I would do is make sure you are set for the altitude you are riding at, some dealers make mistakes or just dont know
The other thing is, the engine makes 90% of peak torque over 1200rpm so if you are off by a couple hun or so it wont make a lot of difference
  • Like
Reactions: SLY
I need a good setup for a non turbo nytro? I'm only pulling about 8200 rpm on the hill.I'm riding around 6000 to 8000 ft mark
I got a clutch kit for your sled its from Tom Hartmen different primary arms, spring, weights, rollers and secondary helix, and spring etc.. I had the same issues with my sled last year put Toms kit in and worked awesome.. I dont need it anymore went with a turbo this year.. Let me know if your interested
780-461-7246
