I might just be ignorant here, but i couldn't find any other bent pieces. the part with the crack and that's bent is th FRONT PLATE, that's seprate from what they're calling the crossmember in the parts catalog.
Also, it was a weird angle, and low speed hit, it wasn't a straight on thing, it was more of a 45 degree where the ski was pushed forward to the right, so the bend is actually forward, not backwards! So what looks like the lower A arm pushed back, is actually the front A arm pulled forward. I'm going to have a friend who knows more about the Rev than me have a look at it as soon as we can get together.
There are no other bends farther back on the crossmember (nun) that I can see, only what I took pictures of. Although I'm being very optimistic and hoping that it's only the $10 front plate what could be done very easily and not the $200 crossmember that looks like A LOT of work haha. I think I am going to try just replacing the front plate, and bending the mounting point back on the crossmember to see if it lines up. It's will definitely need to be replaced and will give me a baseline for checking how straight everything else is. Also going to need new A arm mounts and upper A arm...
With that new info, are you guys seeing the same thing as me..or am I just missing it?
