New reflash for idle
I had the reflash completed as well. I had idling and starting issues, mostly at elevation of 8K and above. Since the reflash, I feel the sled runs better all around and the starting/idle issued are remedied.
:nod:
Tried to talk my buddy out of it but...... he now suffers from a weaker bottom end with the same clutching as before- so... going to try to work that out of it.-
Re-flash seems to always change to much when we want to fix only one thing-
Wonder what mapping the 17's have in them!!!
Also if your TSS is giving you fits the pigtail plug that LoudHandle on here sells- DOES fix those issues- and put's that issue to the grave.
S/C
They are suppose to check the TPS base setting before re flashing the ECU. If that (TPS base setting)fixes it, don't do the re flash. Sounds like the dealer took a shortcut and didn't follow instructions.
I agree with you on that- but as you well know, as it has been discussed on here for quite some time,checking the TPS with the Digital Wrench is not the way to go, which possibly leads to what is resulting from the re-flash...
S/C
