Polaris is coming with a new computer map to help idle and starting, is suppose to be available after march 3rd
Just wanted to pass on
the refllash is for stock non adjusted tps if you flash a sled that has had the tps adjusted you will get a high idle.Set a few already to polaris specs,
these sleds were all done under warranty. No cost to customers,due to low idle and not going into reverseOf course, why would they pay to have the tps properly set! I did my own and it was pretty easy! Just removed some plastic and slid the air box back! Do get me wrong because I love my axys but $13,000 dollar sled should be able to idle at high altitude!
I think the point is Polaris is re-flashing the ECU to mask over the symptoms of the TPS' they delivered out of spec from the factory. And are doing so only to save the company some money compared to paying their dealers to set the TPS under under warranty. ECU Re-flashes like this have lead to performance losses in the past and could here as well, especially for those who've taken the time to set their TPS properly.
Just because the TPS is not set to spec does not mean that its service life will be any shorter. Its still receiving the same 5v input. Just putting out a slightly higher or lower signal. Polaris could easily develop a viable ECU flash that could produce a good idle and easier starts/reverse shifts just by allowing the TPS baseline and idle specs to be a little wider. All the while not ruining any other parameters of the flash. They are not out there to ruin their own product by magically taking away all the power and throttle response. Its a simple software update not a secret government plot to end all snowmobiling.
Has anyone ran the new reflash yet??
I have the reflash...stay away. I would rather deal with the intermittent idle challenges. My worst problem was an occasion need to burp the throttle and then it was fine.
The fueling changes made my sled feel significantly different. Not nearly as snappy on the bottom end.
I have the reflash and I agree that it is not as aggressive on the bottom. I will probably have them reinstall the 16 map when they replace my right running board (paint flaking in non wear areas) this week.
Tried to talk my buddy out of it but...... he now suffers from a weaker bottom end with the same clutching as before- so... going to try to work that out of it.-
Re-flash seems to always change to much when we want to fix only one thing-
Wonder what mapping the 17's have in them!!!
Also if your TSS is giving you fits the pigtail plug that LoudHandle on here sells- DOES fix those issues- and put's that issue to the grave.
S/C
As I understand it, the reflash is the what is in the 17s.
