I will stick with my original statement and when it's done I'll post pics and tell you how much it will cost you.
Curious why the shock mounts on these 36" arms can't be offset to allow stock shocks? I'm sure someone thought about it and there is a reason it can't be done.
Love my X1's on front and back but did the a-arm fiasco get worked out from last year?
Quote from Z-BROZ, "Only major drawback is if you run stock shocks you will need to purchase a spring kit with internal spacer and also a shorter eyelet. All of which we will make available to customers."
i personally have had the chance to ride the 36 wide suspension, and i love it, it makes the sled ten times easier to ride, hard to believe i know.
its amazing what you can sidehill through with this kit. i will have it on my sled and you should to. well worth the money
....I ran the 42" setup last year with exit shocks and rocked it. Side hill all day long through anything the sled would fit through; and then flat out on the trail. I would assume one would lose a pile of stability on the trail. I thought the wide front end was super stabil and once planted on a side hill would stay there forever with no effort and.... this was on an xp.. last year.. then I rode a stock pro-ride... now I have new pro-ride landing any day.. anywho, I feel the need to for ZBROS and exit shocks but am torn between 42 and 36 now.....![]()
What is the stock width on the 11, 12 and 13 Pro. One thing to consider using shocks on these different front ends is what's called wheel rate in the motorsports world(cars). The geometry of the whole suspension has to be considered. You can't just take a shock/spring combo from on set up and use it on another. All of the angles combined will give you different wheel rates or in this case ski rates. So a 200lb spring on an 11 Pro might give a 300lb ski rate but on a different set up the ski rate might be 400lbs. Hopefully that was considered in the designs of these front ends. Not just that the stock shock will "fit". Air shocks will be a huge advantage in ease of tuning the ski rates but dampening will have to be close too.
Stock is 39-41". Ideally I'd like 37" stance with the ability to use stock shock length.
Have FUN!
G MAN
