New motor installation
Looking for some tips and pointers before i reinstall a motor on my 2011 Pro 800. I have it completely disassembled but i want to make this as painless as possible. Should i install the throttle bodies and fuel rail on the bench before the install or should i install them after? Just looking for some advice on the easiest way. I'm assuming i'll want to install the stator, flywheel and recoil on the bench before I start as well. Any feedback would be appreciated.
I haven't pulled my 800 Pro's engine yet for work but did pull an IQ 700 last month.
When I reinstalled it, I had pretty much everything on it including throttle bodies, fuel rail, flywheel, and recoil pull start.
I even bled the oil pump before I installed. You can use a coat rack or a person to hold the reservoir while bleeding the pump. I did this so there be no oil spill mess in my freshly cleaned engine bay. I felt more confident that the pump was bled correctly this way and it was!
