the fix
After having my cylinders honed and having the piston too cylinder wall clearance checked and everything being on the low end of the specs I decided to install my fix kit. Got her all put together one heat cycle than did a compression test......both cylinders read 155 lbs of compression on each cylinder, before with the updated piston it only made a 117 each hole with the same compression gauge. Strike any red flags 40 pounds is quite a bit of change? DETO? Wut do you guys think
