new 900 owner looking for input
T
theUltamateTBM
So I have been helping a buddy out with his 05 900 fusion and now I am ending up with it not that I am complaining I love this sled but there are a few things I hate about it as well first off it gets beat down the trail by everything it trenches pretty bad and has alot of belt heat here is how it is set up it has 10-72 weights an slp green pink spring a black red or red black secondary spring a 66-44-46 helix I think 20-37 gearing and a 121X2 track the motor has v force 3 reeds a fire n ice intake and an slp can I have a vew clutch vents in it and an slp torque arm but my seconday will cook food it gets so hot I am planning on doing compfusion mounts soon any help with this thing will really help me out thanks. ps I will get pics of my new 900 up soon
read the "before you buy" sticky and it will open many doors for you questions. good luck and welcome!
WOW -- A 121 Really
How do you keep it going Straight ?
05 900 RMK IQ
HRP EZ-Steer Spindles
Ryde FX Shocks
2009 Dragon Gripper Skis
Ported / 166 Track
225 lb Carl’s Front Spring
.405 Springs
New Primary / Clutch work Gearing
4 inch PowerMadd Pivot riser
Lefty Throttle
Better Boards
Scratchers
SLP Pipe
CPI Stinger
SLP Head
Carls Porting
V-Force 3 Reeds
Flow Rites
32mm Crank Upgrade
Fire n Ice Intake
well thats not really a mountian sled so yeah it will trench pretty bad if your riding in deep snow make the track longer 144 atleast helix is to steep check out some post here and you'll fined all your answers
it is different to keep it straight esspecially with 8 in of rise to the bars but fun as well and in the tight trees it is awesome the 1 thing it has going for it is that in the deep snow it wont stop it just gets really slow and I will check out the helix being to steep
What is the peak rpm u r running? 10-72s seem a little light. where did u get that gearing from and where do u ride?
Thats the right rpm for an 05 without the pipe. if ur getting beat down the trail it is probly ur gearing. that is good gearing for mountain riding but not so hot for trails. the helix is not too steep in my opinion becuz i run the same one on my switchback and love it! the secondary spring u probly have is the red/black. that is a pretty good secondary setup. trenching on a 121 will always be a problem in deep snow.
so do you have any input on some gearing to try that will help me on the trail but still be useable in the pow
I ride in wisconsin and upper michigan so my gearing will be different but if it was mine i would add like 2 teeth to the top and add 3 teeth to the bottom. ur rear suspension setup will change things as well depending where ur riding.
