H
HOOCH256
How can I tell if fuel pump is going bad.? It'll still read good pressure if it's bad right? I put that different wastegate/actuator in, if that's adjusted wrong would that make it studder?
It's possible, the other day I was riding I wanted to crank my boost up after cruising around at 7# so I gave the knob a few turns and she didn't like it would run up to about 9# and then fall on it's face and jump between 7-9#. Turned back to 7# didn't miss a beat. But I doubt this is your issue you really need to get a solid pull and check what your EGTs are reading. I'm running 1100 on long pulls at 7# which is def on the fat side.
