From what I've seen...the SLP Stage-5 uses the BullyDog tuner.
http://slp.cc/catalog.cfm?pageID=detail&catalogID=3&catID=81&productID=2717
One thing last year, that MAY have been an issue in some early kit production... was that V-Force (Moto-Tassinari) changed their reed-
petal (same reed-block is used) spec on the V-Force-3R reeds when people were having issues... even on stock sleds... I ran the 3R's without issue, but I had a set from later in the season. I've heard it was only on a very small batch of 3R's that were sold early in the year, last year.
Much of the "success" and "failure" has to do with installation and tuning...or an externality outside of the kit, not related to the installation.
One person raves about their kit from mfg-X and another complains that it did not perform well... most of the time, neither are stretching the truth... but their individual result was a result of a that particular installation on THEIR sled.
Especially anything with a "tuner box" on it... if the customer can change the fuel and/or ignition settings for that engine... you often times will hear of a poor running engine, which often gets blamed as "I didn't like my kit" kind of response.
Depending on the condition of a persons injectors (dirty or clean), the condition of the fuel filter, the fuel (and treatments) they are using, if the injectors and fuel pump and/or regulator are within spec...or what end of that spec they are on (higher pressure or lower pressure) can have one sled running "rich" or "lean" and have to be tweaked... or in some cases, have a defective part replaced.
I fixed a buds 2014 800-PRO-RMK last year that had a defective fuel pressure regulator (FPR).. That FPR allowed the rail pressure at the injectors to be 61.5 lbs and the sled always felt rich. I replaced his entire Pump/Flange-assembly (PFA) with the one from my sled for the weekend... which ran dead on at the specified 4-Bar (58 psi) and it ran like it should.... Although this is not common.. it is an example of what can happen in different sleds.
Now, don't get me wrong... someone could have installed it just right, and did everything right... and a kit from MTNTK, SLP etc did not perform to expectations... and it's a mystery. I've seen the same thing on a sled that spent most of a season trying to get worked out... even a couple STOCK sleds here and there throughout the years that was bought back by the factory (all brands) when they could not figure out what was going on.
