Need Help with SLP Clutch Weight? MTX
I just got a set of SLP MTX clutch weights.I'm trying to add weight to the tips but it seems like the rivots just slide into the holes what holds the rivots into the arms. It says "Swage rivets into place with using a hammer and a Anvil keeping weight parrallel with surface.Make sure rivet is swaged far enough to clear spider when installed in the clutch.Not sure what Swage means but that what it says. I would of thought you have press them in they slide freely in the hole.THANKS for Any Help trying to ride tommorw.
You have to hammer the end opposite the head on the rivet. Make sure everything is square when doing it. The shank of the rivet will expand to the size of the hole in the clutch weight when hammering it then the end will mushroom over. A big heavy punch works good.
