M
mcmarkrazz
http://www.polarispartshouse.net/pages/parts/viewbybrand/14/Polaris.aspx#top
which one or all the same ? ty
Definitely sounds like a tps or tps harness problem, I had the same thing happen to my 05 900 and it was the harness. Don't remember the part # but the harness repair kit was around $45 from polaris.
If the check engine light blinked 5 times, would a bad tps harness cause this to happen? Just curious.
the wire that comes outta the pipe was acually disconnected where the pins connect..i fixed this and thought it was the problem but still doesnt run right![]()
anyone no about what it means when the check engine light blinks 3 times?
sled is running like poop......not getting power.....very intermittent power....once rpms get up past around 6000-6500 it kinda chugs...
any help......? thank you
3 blinks is the AIR INTAKE TEMP SENSOR...that goes into the boost box part of the intake...
its either unplugged, or the sensor is broken..
easy fix.![]()
