Ok, doing a little pre ride maintenance and since I have never checked to see if I have any boost leaks I thought it was time. I rigged up at air fitting where the air filter was and when I get up to around 8 psi on the boost gauge air starts leaking out around the BOV, do I have a bad one, or what should I see. I assumed I should be able to pump the gauge up to 14 psi without seeing any leaks.
This is on a Powderlites turbo, and the BOV is built into the lower left side of the intercooler.
Thanks,
Kirk
Thanks,
Kirk
