B
bisonboy02
New member
I have a 2006 900 RMK. I went out on my first ride today since a new motor was installed.
When at a stand still and you hit the throttle it pulls hard for around 2 seconds then just seems to bog out. If you ease into the throttle it seems to work and pull to operating RPM and speed. If I ease into it to about half throttle and then hit it it also seems to bog out and won't pull RPM's.
It is a complete new motor from Polaris, it has new throttle bodies, intake boots, reeds, injectors, ecu, stator, flywheel, fuel filter, coils, FBF throttle cable, sparkplugs, belt and fresh fuel.
There is no check engine light coming on.
Could a exhaust bellows cause this? I did notice when I fired it up today it seemed to have a puff of exhaust come from the small hole on the PTO side plastic cover. There is no oil residue around it. The ves assemblies are also new.
Anyt help would be great.
Thanks
Thanks
