need help 010 BD race-gas kit
scaldedcat
New member
I would like to get your guys input on the build that I am about to start. I will be picking up a 010 HCR tomorrow. I will be putting a race gas kit on it. The kit is one that I bought off the forum a while back. I think the kit is 2 years old it has the Garrett 2860 I think it has the ADA update "I think don't know how to tell" I just bought a new tunnel dump muffler set up. So here are a few questions I have.
1- What updates should I do to the kit to make it work with the 010?
2- Who has the best clutch kit?
3- Should I leave the 010 head on it or go with the 09 head?
There are are a couple things you need to know. I ride most the time from 5-8000 feet I have a friend that just bought a 011 pro RMK with a race gas kit I need to beet this guy or Ill throw a match in the tank. LOL please give me your thoughts! thanks in advance!
No need for matches just parts
First you bought a kit that is not for a 2010 so it will not just bolt on. The box is not going to work but you can make the rest work. Good luck .
Call Pete at Boondockers and he will help you with everything you need to know. Im updating a 2008 M1000 and they have been a lot of help. And (volk here in Co,) You should take your turbo apart to make sure nothing went through it, exhaust side and intake side.
AS for your ADA, the temp sensor with be mounted on the lower end of your inercooler.
I will update my post for my M1000, and that should help you a little with what parts you might need. I would not half A$$ your updates. one thing that will help your sled is to mount the Boost sensor into the air box and get rid of the tubing that runs to it.
Tester- Have you seen a new Pro race gas in action? How are they working? Do you think they are going to hold up? I was thinking going that direction but was worried that with it being a new model it might have some bugs. I don't need to have a sled in the shop when we only get out dozen times a year as is.
MM- So I need a new box. Can I send the one I have for an update or ? What do you think about the 09 or the 010 head?
Are there any other updates/upgrades besides the box to make this BD RG kit fit a 2010 M8? Do you recommend a 2009 head or at least cut the 2010 head? Need more info please.
