I'm thinking about doing the offset also, so I'm curious how well that is working.
Offset spindles work ok.
But if you are going to replace the tin foil stock a arms anyways?
Why not go with narrow arms and save the cost of the spindles.
how many guys notice that when they offset their skis with the spacers on the ski bolts?
I’m running the Alternate Impact 36” front and like it as wide as possible. I tried it with ZRP spindles too at 33 1/2”, it wasn’t what I like. I run stock length shocks with triple rate raptor springs and have no issues, I wouldn’t shorten the shocks. I could sell my ZRP spindles if you want them, they are just sitting on a shelf.
cousin just put alt impact of his terrain dominator and with in the air it steers really light and easy. as soon as he set it down on the dollies it steers hard as hell. looked at a everything and dont see anything binding but it is definitely not right. he said that all the setting are by the book and everything is exact and spot on. any thoughts?
Give me a call, something is probably not set up correctly. As mentioned more information is needed. Send me some pictures of how you've got the rod ends adjusted and I'll more than likely be able to help you out with just that. Too long of a shock is suspect if it's free in the air. As long as it's stock shock Length RMK from 2013-19 with the true clearance kit you should be fine though. Again, send pics, it's something simple.my cousin put on alt impact and it is set to the instructions for the dimensions and when it is in the air it turns nice and freely but when he sets it down on the dollies it turns stiff and really hard. cant see anything rubbing or binding but something definetly is not happy. anybody have this experience or any thoughts? thanks!
