got her sled out for its first ride yesterday, was a great day overall.
had some very minor issues that i can take care of quickly...but nothing major at all.
1. running 71g MTX weights with 2g in the outter tip, might remove the 2g and see if i can get the bottom end to "snap" better...but the rpm range is great and pulls hard
2. The steering alignment is WAY off, lol...not sure what the heck i was doing when i did it a few weeks ago, but its not right. haha.
3. the Hyfax needs to be trimmed back about 1" on both sides by the rear wheels
4. the belt was squeeling at idle and noticed the belt deflection was too tight..so went to adjust it on the trail and i forgot to bring the allen head and wreck for the adjustment screw, lol...easy fix though
5. the damn Highrise BOSS Seat drove me NUTS....it would colapse under the weight and pop the botton flaps off the side of the tunnel and wiggle all over the place...velcro was the only thing holding it on at that point...so will fix that last and see what ideas come to me to keep it on there nice and tight...
but no major issues at all, east fixes i will do asap.
temp was 115-120 all day on the trail with scratchers...stopped a few times to check/bleed coolant....re-torqued the primary bolt a few times over the day (70ft lbs per indydan) and adjusted the PSI in the floats shocks...
the 43" wide ZBROZ front end is something to get used to also, but didnt feel right at all since the alignment was off, so will play with that, lol.
so this is how it will sit until this summer when i convert the black/pink theme on this baby and really set it apart from the others
