my fusion 700 need crank case and cylinder $1900 what to do
M
mcmarkrazz
thats the damage i got quoted for the repairs.. no idea what to do and cant seem to find a used crank case or cylinder anywhere to save the money..is this worth fixing or could i get some money back by parting it out..stock 2006 fusion 700..had it for 1 season or great riding to have this happen what a bummer..anyone have some thoughts or ideas for me ? i would have to borrow money to fix it and really cant afford it..
i am really sorry to hear that happend man..
the question is..
--do you really like that sled...if you were to fix it, would you be willing to ride it for at least 2 more seasons or keep it as long as possible
well, if it were me...this is what i would do..
call IndyDan..
ask if he can hook you up with the TMI/TMII/TMIII crank and some crank cases...he will line bore the cases to fit the crank perfectly..then you will a great stout crank with warranty by the best in the business..
I have no idea what his prices are right now...but you need to get ahold of him asap before he starts building other sledders engines in the summer!!!!!!!!!!!!!!
he can also get you a TOP END kit for a good deal as well
that alone is WAY better then your quote..
here are some cylinders on ebay, 2 used and 1 brandnew..
http://cgi.ebay.com/ebaymotors/Pola...76712515QQptZSnowmobileQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/06-P...24557033QQptZSnowmobileQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Pola...850755QQptZMotorsQ5fATVQ5fPartsQ5fAccessories
give Dan a call first, he might be able to get you back up and going for alot cheaper, and have the parts on stock for you to get up and going...WELL Worth it bud..
good luck my friend..
I'll second that! No point in spending a ****load for somethig stock when you can upgrade to perfection for the same or maybe even cheaper!
How do you get a hold of Indy Dan? Is he a member of this forum? I'm in need of crank case, cylinder, and crank myself
thanks Eric..
it would be MUCH better if you called him..he is VERY busy, and doesnt get to his email much...and if you call he will drop things and chat with you, or set a time to call you back..
Great Guy!
the question is..
call IndyDan..
SO DOES HE FIX THE SLED ALSO OR JUST MAKE PARTS IM A LITTLE CONFUSED ? HE IS A WAYS AWAY BUT IF I COULD GET IT FIXED AND HAVE IT BETTER THAN STOCK FOR LESS IT MIGHT WELL BE WORTH THE TRIP UP THERE..
he does not make parts..but he can get you anything you need and fix it for you..
he usually has you ship him the engine and then he will repair it, and build the entire engine for you..
or you send him say..your crank/cases and he will build it, and ship back to you for you to complete the engine build
give him a call and see what he thinks will be suit your situation ;)
