You have it right behind a large air vent in the hood.
I mounted mine as close to the Y pipe as possible. It sits almost flat so it won't leak and make a mess. Get some meatballs, BBQ sauce, crock pot bags to put it all in and tooth picks to eat with. Shrimp, garlic paste and butter. The list goes on and on. When you are sick of the normal stuff try a Hot Pocket.
the only reason i didnt mount it on the y-pipe is that the powervalve cables are look like they would make it a bit of a hassle to open and close. and i mounted it sideways so there was more metal to metal contact with the pipe but i will probably try and mount it flat so it doesnt leak.
Thanks for all the comments and suggestions.
Don't mount it on the Y Pipe, mount it just forward of it. I need to mount mine this weekend. Like I said, mine was tapping the head shield on the hood, so I may need to fine tune the mounting and it's should be fine.
I had it mounted a little more forward than yours I'll try it again since it obviously fits there thanks for the help cant wait to make a feast next weekendOne more hint. Don't run your sled with out the pot in place (empty). The lever over the top will vibrate and fall off. It can fall in the throttle cable control area.
